Интересуют цены и сроки.
<table class="MsoNormalTable" style="border: medium none ; margin-left: -0.9pt; border-collapse: collapse;" border="1" cellpadding="0" cellspacing="0"> <tbody> <tr style="height: 15.6pt;" height="21"> <td style="border: 1pt solid windowtext; padding: 0cm 5.4pt; width: 296.85pt; height: 15.6pt;" height="21" valign="top" width="396">
Наименование<o
></o
</td> <td style="border-style: solid solid solid none; border-color: windowtext windowtext windowtext -moz-use-text-color; border-width: 1pt 1pt 1pt medium; padding: 0cm 5.4pt; width: 70.15pt; height: 15.6pt;" height="21" valign="top" width="94">
Тираж<o
></o
</td></tr> <tr style="height: 30.75pt;" height="41"> <td style="border-style: none solid; border-color: -moz-use-text-color windowtext; border-width: medium 1pt; padding: 0cm 5.4pt; background: yellow none repeat scroll 0%; -moz-background-clip: -moz-initial; -moz-background-origin: -moz-initial; -moz-background-inline-policy: -moz-initial; width: 297pt; height: 30.75pt;" bgcolor="yellow" height="41" valign="top" width="396">
Конверты для авиабилетов. Формат 225х115 мм (в сложенном виде), 225х230 мм в развернутом, внутри карман для билета, 4+4, бумага 200г.мел.мат.
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; background: yellow none repeat scroll 0%; -moz-background-clip: -moz-initial; -moz-background-origin: -moz-initial; -moz-background-inline-policy: -moz-initial; width: 70pt; height: 30.75pt;" x:num="100000" bgcolor="yellow" height="41" valign="bottom" width="93">
100 000 <o
></o
> </td></tr> <tr style="height: 30pt;" height="40"> <td style="border: 1pt solid windowtext; padding: 0cm 5.4pt; background: yellow none repeat scroll 0%; -moz-background-clip: -moz-initial; -moz-background-origin: -moz-initial; -moz-background-inline-policy: -moz-initial; width: 297pt; height: 30pt;" bgcolor="yellow" height="40" width="396">
Вкладыши в конверты с авиабилетами, 190х84 мм, 150 мел.гл., 4+4<o
></o
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; background: yellow none repeat scroll 0%; -moz-background-clip: -moz-initial; -moz-background-origin: -moz-initial; -moz-background-inline-policy: -moz-initial; width: 70pt; height: 30pt;" x:num="100000" bgcolor="yellow" height="40" valign="bottom" width="93">
100 000 <o
></o
> </td></tr> <tr style="height: 15pt;" height="20"> <td style="border-style: none solid solid; border-color: -moz-use-text-color windowtext windowtext; border-width: medium 1pt 1pt; padding: 0cm 5.4pt; width: 297pt; height: 15pt;" height="20" width="396">
Стикеры, формат 400х200 мм, пленка самоклеющаяся, 4+0, клей съемный<o
></o
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70pt; height: 15pt;" x:num="1000" height="20" valign="bottom" width="93">
1 000 <o
></o
Стикеры, формат 300х150 мм, пленка самоклеющаяся, 4+0, клей съемный
1 000 <o
></o
Стикеры, формат 200х100 мм, пленка самоклеющаяся, 4+0, клей съемный
1 000 <o
></o
Стикеры, формат 250х50 мм, пленка самоклеющаяся, 4+0, клей съемный
1 000 <o
></o
Стикеры, формат 1450х250 мм, пленка самоклеющаяся, 4+0<o
></o
1 000 <o
></o
Стикеры, формат 950х250 мм, пленка самоклеющаяся, 4+0, клей съемный
1 000 <o
></o
Стикеры, формат 710х140 мм, пленка самоклеющаяся, 4+0, клей съемный
1 000 <o
></o
Стикеры, формат 770х390 мм, пленка самоклеющаяся, 4+0, клей съемный
1 000 <o
></o
> </td></tr> <tr style="height: 34.75pt;" height="46"> <td style="border-style: none solid solid; border-color: -moz-use-text-color windowtext windowtext; border-width: medium 1pt 1pt; padding: 0cm 5.4pt; width: 297pt; height: 34.75pt;" height="46" width="396">
Стикеры, формат 300х100 мм, пленка самоклеющаяся, 4+0<o
></o
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70pt; height: 34.75pt;" x:num="500000" height="46" valign="bottom" width="93">
500 000 <o
></o
> </td></tr> <tr style="height: 26.75pt;" height="36"> <td style="border-style: none solid solid; border-color: -moz-use-text-color windowtext windowtext; border-width: medium 1pt 1pt; padding: 0cm 5.4pt; width: 297pt; height: 26.75pt;" height="36" width="396">
Стикеры, формат 180х240 мм, пленка самоклеющаяся, 4+0, клей съемный
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70pt; height: 26.75pt;" x:num="500000" height="36" valign="bottom" width="93">
500 000 <o
></o
> </td></tr> <tr style="height: 33.3pt;" height="44"> <td style="border-style: none solid solid; border-color: -moz-use-text-color windowtext windowtext; border-width: medium 1pt 1pt; padding: 0cm 5.4pt; width: 297pt; height: 33.3pt;" height="44" width="396">
Стикеры, формат 220х180 мм, пленка самоклеющаяся, 4+0, клей съемный
</td> <td style="border-style: none solid solid none; border-color: -moz-use-text-color windowtext windowtext -moz-use-text-color; border-width: medium 1pt 1pt medium; padding: 0cm 5.4pt; width: 70pt; height: 33.3pt;" x:num="500000" height="44" valign="bottom" width="93">
500 000 <o
></o
> </td></tr></tbody></table>
<o
> </o
<o
>Заранее спасибо!</o
<o
></o
<o
</o
